Oooh....Still got the 35?The way it revs I agree. Plus I ran over my wheel chocks in reverse with no throttle. Poor Dana 35
That's not going last, I killed mine with a 2.5.
Ended up with a custom 35 spline D489 @ about $3400.
Suspected as much...Please do not get yourself killed with that beast!!Okay everyone. She is done. Wiring heat shielded. Everything hooked up. And it is way to fast for a YJ. Time to make questionable life choices.
Ok. I need some info from you. Do you have what flywheel to get? And measurements for the motor mounts, so I can weld them in at the right location.
The flywheel was out of a 07ish Dakota 4.7. Any 3.7 4.7 5.7 flywheel should work if its internal balanced 8 hole. I used the holley black heart mounts and they went in exactly as described. I loose set them to verify and they ended up just as described. Holley has the instruction on their website. I used standard Chevy ls rubber inserts but had to grind off the locating tabs.Ok. I need some info from you. Do you have what flywheel to get? And measurements for the motor mounts, so I can weld them in at the right location.
Sweet. Thank you. I got a bellhousing out of a liberty since I saw that it would work, then realized I had to use a 10 3/8” flywheel, and I’m guessing that I may not find the flywheel to mate to the engine. And thanks for your diagram on the pilot bearing, just made one!The flywheel was out of a 07ish Dakota 4.7. Any 3.7 4.7 5.7 flywheel should work if its internal balanced 8 hole. I used the holley black heart mounts and they went in exactly as described. I loose set them to verify and they ended up just as described. Holley has the instruction on their website. I used standard Chevy ls rubber inserts but had to grind off the locating tabs.
Once I get back from my deployment, I’m probably going to have a lot of questions for you.The flywheel was out of a 07ish Dakota 4.7. Any 3.7 4.7 5.7 flywheel should work if its internal balanced 8 hole. I used the holley black heart mounts and they went in exactly as described. I loose set them to verify and they ended up just as described. Holley has the instruction on their website. I used standard Chevy ls rubber inserts but had to grind off the locating tabs.
The 3.7 flywheel should bolt up that I know of. The 11" Dakota clutch is about what I would say is minimum though. And consider upgrading the traction devices.Once I get back from my deployment, I’m probably going to have a lot of questions for you.
Any thing I can help with just let me know. I have about 3000 miles so far and the only issue was the clutch master. The master barely puts out enough volume to disengage the new clutch disc.Once I get back from my deployment, I’m probably going to have a lot of questions for you.
