Hello all, me again.
I’m just finished up an engine rebuild of my 94 4.0. Took it for a test drive and noticed the engine temp was maxed out.
Here is what I have done;
Pulled thermostat, tested it in a pot of boiling water, and drilled air escape hole.
Water pump is new and rotating the proper direction.
Obviously flushed and used all new 50/50 coolant.
Burped the system with front end up on a log, no more air bubbles are coming out.
Top radiator hose gets hot, lower is warm. Both heater core hoses get hot. Heat blows hot.
This is the part that stumps me, after replacing the water temp sensor at the back of the block, no coolant leaked out of the head as if it were empty. But when I pulled the thermostat there was coolant in the head. All the videos I have seen, the coolant shoots out like a waterfall.
Now I’m trying to see what my next likely steps would be.
*Update* Just walked out and pulled the radiator cap and coolant spewed out of the temp sensor hole.
Thanks,
Tyler
Thanks,
Tyler
