1994 Hunter Green SE “Back to Stock” Thread
I've got the Rampage H4 housings on mine, but what made the biggest difference in lighting quality was wiring the headlights directly to the battery with the Putco relays and harness so that power to the headlights is no longer routed through the wiring to the dash switch. You could create the harness yourself, but the pre-made harness made it an easy modification.
I’m definitely wanting a premadeKit/harness (with instructions if possible). I hadn’t heard of putco but it looks good to me.
Hey all, some of you may have seen my other build thread. I think I’m going to stop using that one. Over the years there’s just been too much done, undone, and changed and it just makes for a confusing read.
I have recently decided that I want to put my Jeep back to stock in most ways related to the functional design. This means stock height, relatively small tires, stock steering & angles, stock axles, BUT can also include some functional improvements, like a TrueTrac LSD rear, possibly a front locker, LED lighting, better audio, etc. Essentially, this is my take on a true OEM+ type of thing.
The backstory as I outlined in the other thread is that this was my grandpa’s YJ. He was the third owner. He died in 2008, I bought it from my grandma in 2013. It was the summer of 2013, before I started senior year of high school. Best summer ever.
How it was when I got it:
The YJ came with some dry-rotted 31x10.50s, aftermarket chrome steelies, 6” fender flares, side steps, door armrests, a windshield sticker and a spare tire cover. Otherwise, it was bone stock. The tires needed to be replaced and since I was new to automotive, I figured I should just stay with the tire size that was already there, so I got a set of 31x10.50 Duratracs. The chrome steelies weren’t my thing at the time, so I got a set of Cragar black Soft 8 steelies.
How it was after the new wheels/tires:
The 31’s looked pretty cramped as they always do on stock suspension, so naturally instead of downsizing the tires, I opted for a lift. This is what started the unfortunate mod cascade that I could never seem to bring to a halt. Long story short, I went through multiple suspensions, including Rough Country 2.5”, BDS 3.5”, and OME 2.5”. I loved the OME 2.5”, but ultimately I don’t want lift anymore. The other two lifts were garbage. BDS was horrible.
After the 2.5” lift (it did look sharp)
Supporting mods for those suspensions:
  • JB Conversions SYE
  • Adams driveshaft
  • Tummy tuck (for 33’s that didn’t happen)
  • Motor mount lift (for the 33’s)
  • Body lift (for the 33’s)
  • Drop pitman arm
  • WJ suspension
  • 3/8” MORE Shackles
  • Pinion shims
And I’m sure there are plenty of others I’m not thinking about.
Eventually what changed my mind on all this is that I stared to ask myself - “what is all this for?” Over the years it seemed to handle worse and worse, which I sort of answered with “it’s a Jeep,” but I don’t like that answer. It doesn’t have to handle like crap; it didn’t when I bought it. The mods I’ve spent years worth of time and money on literally provided no benefit except maybe cool looks. But even a stock jeep looks really nice to me.
Eventually I said screw it, I’m going back to stock, and that’s that. With that, here are the plans:
  • TJ Grizzly Silver 15x7 5.25” BS aluminum alloy wheels
  • 30x9.5R15 all terrains (little bigger than stock 27.5s)
  • Dayton stock height non-HD suspension (4-leaf front 5-leaf rear) (done)
  • All new stainless brake lines from Inline Tube (done)
  • All new flex hoses for front calipers and rear frame to axle brake hose (done)
  • Rebuild front Dana 30 HP with 4.10 gears (possible e-locker eventually)
  • Source and rebuild rear Dana 35 with 4.11 gears and Detroit TrueTrac
  • Stock Chrysler/Mopar pitman arm (done)
  • Transfer case rebuild, converting back to stock slip yoke design
  • Stock new AX15 (done)
  • Stock sway bar links
  • Reinstate stock track bars
Some of it is not “stock,” but are improvements. Such as the gearing and traction devices. I am okay with these not being factory. Open diffs don’t benefit me and neither do tall gears. The design intent is still stock.
I’m sure there is plenty I’m forgetting on this list as well. I probably come across as crazy for doing this, especially with as much money as I’ve spent. It’s unfortunate I change my mind so much, but I just can’t ever let myself not sweat the small stuff. There were many aspects about the build that I just didn’t like anymore, and going back to stock is the one true way to get the YJ handling the best it ever has. I’m honestly stoked for the results.
I’ve already gotten started on some of the stuff, I’ll try to update the thread as I go. I’ll eventually be doing things like an amp and speakers as well but I just really need to get this thing on the road. I’ve said it for years, it’s not that far from hitting the road but I keep finding reasons to tinker. With me reinstating the stock design that should come to a close soon. Right now I’m just waiting on more parts.
So there’s the backstory and about as much as I want to drone on about the history. Too many words is just not interesting and I’m probably beyond that.
At this point, I’m just bringing it back to what it once was in its past, and this thread will be dedicated to that purpose!
Appreciate your thread. This is a tremendous amount of information. Thanks.
