Tire PSI
sbcyj89
maryland
What tire PSI are people running. I just had 33 x 12.5 put on an 89, when i got it, it had stock dry roted tires that leaked on it. It use to have 33x 12.5 one it but those were undrive able and didnt know what pressure they were at, the place that mounted new tires, had the pressure at 40, i lowered it to 35. Wonder where people are running their bigger tires at.
Definitely not 40. More like 20, give or take.
I base tire pressures off of the stock TJ tires, which were 30X9.50R15LT B on most trims at 29 psi. This leads to 1376lbs of carrying capacity per tire, for a total of 5,500 lbs. which is a reasonable baseline for what a Wrangler at road speeds needs. TJ and YJ need the same pressure since they are the same size/weight. You can use the YJ tires as a starting point, but honestly they were way overinflated from factory. The TJ got it right.
Use this tire pressure calculator
So, start with the "stock" tire on the left:
LT (bottom option)
30X
9.50
R15
B (96)
29 PSI
Now select the new tire:
33X
12.50
R15
C (108)
You can see the tire calculator recommends 25 PSI, because LT thigh flotation tires (inch size) are only rated to a minimum 25PSI. However, this tire at it's minimum pressure still has extra capacity over stock by 389 lbs per tire. That's an added 1,556 lbs total to the carrying capacity of the Jeep, which is excessive.
So, I would want to lower the pressure even more. How I figure out where I would want to put it, is I play with the calculator some more. I now enter the 33x12.5 info in the left side and change the PSI so I can watch how much the load carrying capacity changes with 1psi.
Changing from 35 PSI to 34 PSI, you can see the load capacity changed by 41 lbs.
This means that for every 1 PSI, the tire carrying capacity drops by 41 lbs. So take the 1765, subtract the 1376, you get that 389 lb number I referenced earlier. 389/41 = 9.48, so 9. You'd want to actually run 16 PSI to support the load like stock.
That sounds crazy low, but in reality you can try it and go from there. You can also do the chalk test, but I don't really like the chalk test. You could keep it at 20 PSI if you felt better about that. But at an absolute maximum, I would not be running them higher than 25 PSI, and that still has a much higher carrying capacity than stock.
LT (bottom option)
30X
9.50
R15
B (96)
29 PSI
33X
12.50
R15
C (108)
Thank you. that was a lot of work. Really appreciate it all. I will try it at around 20 and see how it is.
LT (bottom option)
30X
9.50
R15
B (96)
29 PSI
33X
12.50
R15
C (108)
Jeez Macho that’s pretty scientific. I usually just added or subtracted air psi until it looked and felt right.
It is, but it helps to confirm low pressures are safe. Somebody continually lowering the pressure to abnormally low sounding numbers might be concerned about doing so, so I like to share the process of calculating it out. It’s really not that complex, and on all the other vehicles that aren’t super lightweight with large tires like Jeeps are, it’s typically just a simple watering of two tires into the calculator and seeing what it spits out.
But I do agree, lowering air out until it looks/feels right will do the job, and I’d bet a decent amount of money that that would happen around 16-20 psi. I don’t know why the teenagers at the tire shops are taught to air all tires way beyond where they should be.
