I’m replacing the two body mounts in the crossmember in front of the fuel tank (I’ll get to the rest of them later), and the new rubber isolator doesn’t seem to fit through the opening in the crossmember.
I’m using Crown 5200 2660, which I confirmed is the part number from the Factory parts list. The metal post fits nicely into the rubber isolator, but even with silicone grease and the entire weight of the tub on it, it wont fully seat through the crossmember. It is holding the tub up off the two nearest mounts:
Ideas? Should the rubber go in first then get the metal cap on last?
