I just went through this while fixing a Jeep Patriot and found continuing codes after using and replacing various sensors several times.
After going to the local dealership the service manager said don't ever use aftermarket sensors on these Patriots because the computers will often not recognize them. The OEM sensors worked perfectly for just a slightly higher cost but worth all the time wasted.
So how does that work for the YJ? Are OEM sensors still available? If so, that's where I'm going.
