Need a new clutch and help identifying transmission
Tanner
Rapid City
Im building a 94 yj for a daily that is also built enough for some tails, its a 4.0l with a 5 speed. I need a new clutch and transmission im pretty sure its an ax15 but im not 100% sure. Anyone able to verify what it is and what clutch kits do you recommend? Eventually ill motor swap it so im not sure if i should look for a stage 2? The transmission has an exterior slave cylinder if that helps.
