Glad you enjoyed the Zone, sounds like it was just as well you didn't go to Sedona.More Axle Stuff
On the AZ trip, I also met @jeepjoe43 who I sold my old empty Dana 30 to. He had a similar ideal in his mind that he could get my axle built while he drives around on his current one. Then once it's ready, just install right into place. During our exchange, he nicely gifted me a DV8 super swamper tread diff cover. Thanks Joe! I'll get a pic once it's installed. Amazon actually delivered my Lubelocker gaskets a few minutes ago so it'll be soon, hopefully today or tomorrow.
After getting home from the trip, I realized I have a hell of a lot of stuff to do! I got the 30 cleaned up some more, put it on some stands, and painted it with rust converter and VHT epoxy black paint. I don't need it to be beautiful, I just wanted it to look black and not rusty under the Jeep. The axle I sold Joe was black as can be, so I at least needed it to look like I wasn't downgrading myself lol.
With the help of my brother, I set the 30 up in place on the springs. Yesterday I rented a ball joint press and installed my 2 Spicer Ball Joint Kits. They went in perfectly. The knuckles that came with my front axle also were in pretty poor condition, but I installed them temporarily so I could get the Jeep on it's wheels again. With this recent axle adventure, I am going back to stock brakes and steering. No more WJ swap for me.
To complete the front, I ordered:
Pitman Arm Nut
Two steering knuckles
Two brake shields
Once I receive these I can hook everything up and go for a drive soon.
After getting the Dana 30 in place, I tried my luck with the Dana 44. Lo and behold, it fit the springs freakin' perfectly! I pulled the shims from the springs so I could take some pinion angle measurements. This axle was impossible to weld perfectly without the Jeep present, because the Dana 44 is longer at the pinion, which shortens my driveline, and the JB SYE uses a high clearance yoke, that shortens the driveline a bit. Not wanting to risk it and weld the pinion too high, we guesstimated a bit low on purpose. With no shims, the axle is at 11 degrees and the driveshaft at 24 degrees. According to Tom Wood's pinion angle calculator, with my 17" driveshaft, I need a 5 degree shim. This makes sense because as you rotate the axle, the pinion lifts up the driveshaft u-joint which means 1 degree of shim actually adjusts the angle difference by roughly 2 degrees (the exact amount depends on length of driveshaft). I went ahead and ordered some 5 degree shims from Tom.
View attachment 117667View attachment 117668
Even the shock mounts were 100% perfect. We managed to install them in such a way that the shock never hits the tube, yet is not too far forward to hit the fuel filter skid plate either. Thankfully, the YJ doesn't offer a lot of uptravel so it's not like the shocks have some crazy travel anyways, but it's still easy to be concerned when you can't do the welding in person. This actually worked out better anyways, the OME shocks don't allow much downtravel because they are pretty short. They never bottom out due to the YJ's lack of uptravel. The way we welded the shock mounts a bit higher actually allows the shock to travel all the way down and stops at the same time the suspension does, so no loss of downtravel now! The springs don't flex up enough to bottom out so no issues there regardless.
Once the degree shims arrive, I'll pull the 44, paint it, and take some pictures, especially of the spring perches and shock mounts. I am ecstatic with how well it fit. Patrick (the Arizona friend) is very good at this type of stuff so I wasn't too worried, but there's always that doubt when you don't have the vehicle with you to confirm. I'm very glad it all worked out and certainly glad to have his help and expertise with axle work.
To go with the 44, I ordered:
New Caliper Hoses
New Coated Rotors & Pads
New Parking brake shoes & hardware
The LJ axles use this funky combined hard and soft line hybrid, so I ordered a flaring tool and will cut and flare the line so I can install new hoses myself.
After the 44 Axle is done, I will be piecing my Dana 35 back together and hopefully selling it. It is a 4.10 ratio, setup and plumbed for disc brakes, and is overall a nice condition axle. It would make a good axle for someone with a mild build plan that wants disc brakes. I also have the super 35 shafts so it would make a good build for someone wanting to run a locker as well. I only ever changed plans because I decided I wanted a LSD instead of a locker out back.
Interior
Before I left, I ordered Bestop seat covers to go with the ACC carpet kit I had also ordered. Both arrived while I was gone, so those were nice to come home to. Only the rear Bestop seat cover arrived so I went ahead and got it installed. Not the tightest fit ever but seems like nice quality and will do the job. Certainly will clean up my ratty grey cloth seats a decent amount at least.
The carpet kit is extremely nice. This carpet is way thick, the mass backing adds a lot of thickness and weight. That will help it hold it's shape and not blow away in the wind. It also comes with jute padding adhered to large areas for extra noise isolation and comfort. It is charcoal color but turned out sort of brown. Not a big deal though, should look good in the Jeep and it certainly doesn't look as brown as the pictures.
View attachment 117671View attachment 117672View attachment 117673View attachment 117677
Thanks for the props brother, may it serve you well! That's going to look good on a nice clean axle!
It never even saw mine.
And mad props to you for dragging that axle across the country for me.
I didn't get home in time to order any parts, got caught in holiday traffic, but not too bad.
And I decided to drive straight home and not drop it my buddies shop, it's still in the trunk of my hoopty.
But that's OK, because I love the smell of hypoid in the morning! lol
That is a nice looking carpet kit, BTW.
I'm sure pics don't do it justice.
Wish you could have seen more, but a lot of it looks like that.Yeah I did, I didn’t get to see much sadly but it was cool nonetheless. Maybe someday I’ll make it back out that way. It sure is a long drive if you don’t have a reason to go out there though lol.
Looking forward to the cover in place, should look good.
I think that carpet will be really nice when done. It’s going to be a bit of a pain to install but will be worth it. Really will clean up the interior.
At this point I’m just itching for all the parts to ship so I can get done. I enjoy building the Jeep but I’m ready to stop for a while and just drive & enjoy it.
Can't imagine living anywhere else, though Summers are a bitch which makes Summer wheeling pretty much nocturnal.
Looking forward to seeing pics of the finished projects, you do indeed have a lot work ahead of you...
Glad we could contribute to one-another's builds, now that's how I define "A Jeep Thing"!
