just bought 89 yj w/33's and dana 35 rear/30 front both have lockers in them . Problem is gear ratio is close to 300 (3:08?). How low of a gear can I change to without getting rid of carriers, 4;56s? thanks. New to thread.
Yes, new carriers will do it. I believe they are the 44590 and the 706008x carriers. You will need sets of spider gears for them.awsome! thanks for info. so if want to go to 4:56 gears there are new carriers that will take them? Rear acts like a lunch box but seller did not know. bought a project to sort out. I'm okay with going back to open diffs for now
No confusion, if the lockers are the lunchbox type they can be reused in the new carriers. that should save you some cash.thanks for the reply. I'm trying to change out the 3:07 gears to 4:56 gears and needed to know if the 3:07 carriers would except the 4:56 ring gear. sorry about the confusion
