Flywheel bolts
When I rebuilt my 92 YJ 2.4L two years ago I had the same problem and called the local dealership. They checked the inventory across the US and found one last remaining set up in Illinois. I was able to purchase them and get them shipped down to me.
During my initial search in various forums most people had no clue about the one time use stretch bolts and always reused the ones they removed. I can't recall if they are the same as the 4.0 or not. Maybe take one to a dealer and match it up to the 4.0
The spec calls to torque to 50ft/lbs then another 60 degrees. I bought the dial at Advance Auto
4.0 and 2.5 bolts are different. The 4.0 you torque to 105. I believe they are the same in that you shouldn't reuse them.
