I came across a solid deal on a 95 Sahara, 63k with no rust on the tub or frame. Seen it's share of mud and offroad and no maintenance for a long time but overall in good shape. I really wanted another manual but this one is an auto. I had been looking for many months for a decent YJ and when this one popped up, I decided to jump on it with the idea of swapping it. I have manual swapped a couple of cars over the years but never a Jeep. I found a thread with some good info on this forum, so I figured I'd add mine here as well and introduce myself.
I have amassed the parts I need (I believe) to complete the swap. Decided to get a new AX-15 from Novak so I know that one thing should be good for a long time. Got the external slave bellhousing and the slave/master cylinder for the clutch. New Luk clutch and flywheel. I had a manual tilt column I pulled from the yard a year ago and had already rebuilt it for a different Jeep that I wound up not using, so that will work great for this. Clutch and brake pedal assembly along with the transfer case shifter mount assembly from a manual setup. I will be re-using the transfer case but am anticipating needing to pull the tail shaft as I have read they are longer in the auto/TC setup than in the manual. Considering just rebuilding the TC since I have to open it up anyway to do that.
Also doing a lot of maintenance as this Jeep has not seen any love in a long time. Idles and runs okay but leaking oil all over. Found the valve cover bolts loose and two missing in the back, looks like it still had the oem cork gasket on it. So I am going through and cleaning it up and replacing a lot of worn items while I am at it.
Just need to get the wiring changes figured out, found some good info here that should be helpful. I had a 91 4.0 that I parted out and I transferred a bunch of parts over from that one already like the RE Express lift and wheels and tires, etc.
Really looking forward to hopefully getting this thing on the road soon. Great Jeep weather here in Daytona Beach this time of year.
