Check out these specs..
Front Axle Complete
Dana 489NR High Pinion YJ Front Bolt in Axle Assembly
(BOM-D489F-NR-YJ)
AXLE WIDTH - WMS:60.5
Select Ball Joints: Synergy Chromoly Ball Joints (+$154.00)
SELECT LOCKER: GRIZZLY LOCKER (D44-GRIZ-3-30) (+$550.00)
SELECT GEAR RATIO: D44RS-488
Add Gear Oil: Gear Oil
Add Knuckles: Add New Knuckles 1989 & Down (+$450.00)
SELECT DIFF COVER:YUKON HARDCORE (DC
44-YHC) (+$100.00)
Spring Perch: Spring Under
Select Handling Charge: Local Pickup - 7.25% Tax Applies
Rear
Dana 489 YJ Rear Bolt In Axle Assembly - 35 Spline
(BOM-489-YJ-R)
SELECT LOCKER:ARB (+$945.00)
Ebrake Cables: YJ 87-90 (02/01) (+$90.00)
Suspension Lift: 5.5"-6.5"
Driveshaft Style : CV-SYE
44-YHC) (+$100.00)
SELECT RATIO: 4.88 (BO-D489NR-RG-488) (+$525.00)
ADD LUBE LOCKER GASKET: LUBE LOCKER (+$24.00)
SELECT YOKE: 1310 (+$60.00)
UPGRADE DISC BRAKES: Disc Brake / Set 20 Upgrade (+$550.00)
WMS:60.5
They're only 3 hr drive, no sense in shipping them when I can save that money and pick em up. Think I'm just going to go this route.
