A lot of mine are filled with the roll on bed liner that the entire Jeep was covered in when I got it. A torch and pick usually has to be used to clean the bolt heads out. I would never use that crap.One of the biggest culprits is junk being in the cavity of the head. You must start with that area cleaned out or the socket won't bite properly. The other thing is carefully placed heat. Then sometimes they still won't come and you have to get creative.
Yep. One I was trying to remove was the seatbelt buckle end and i should’ve vacuumed out the plastic sleeve first. Also was getting pushed a bit off center by the opening in the plastic. Will have t get creative, since i want to reuse the sleeve.One of the biggest culprits is junk being in the cavity of the head. You must start with that area cleaned out or the socket won't bite properly. The other thing is carefully placed heat. Then sometimes they still won't come and you have to get creative.
