Quick review of my current blinker set up - I've got LED taillights in the rear (complete replacements) and LED bulbs in the front blinker locations. I've got electronic relays under the dash for both blinkers and hazards. Flash rate is perfect on all four corners whether I'm using my turn signals or hazards.
That said, I noticed something new recently. When the headlights are off (during the day) all the blinkers act perfectly. As mentioned, they all blink at the correct rate, and more importantly, they all blink completely. In other words, Blink-Off-Blink-Off.
Last night, driving with the headlights on, I noticed that they are blinking at the correct rate, but the fronts are not blinking completely. What I'm seeing is Blink-Dim-Blink-Dim. Makes it a bit confusing for other drivers to determine if you're really using your blinkers or not. Everything looks normal in the rear. No issue there.
I swapped out to different LED bulbs in front. Same problem. I tested this with turn signals and hazards (which have different relays), same problem. I tested with low beams and high beams. Same problem. My headlights are LED units (complete housing replacement, not just blubs). I'm a bit confused by any relation between turn signals and headlights. Any thoughts on what might be going on?
