NP231 transfer case without vacuum lines
Dgroce
Walker, LA
Just replaced my transfer case on my YJ and the new one does not have a connection for the vacuum lines and therefore my Jeep stays in 4H. What can I do to use the newer transfer case without the vacuum lines and still allow the Jeep to shift to 2H, or 4L?
Check out the alternatives to the vacuum operated CAD setup in the How To section of the forum here:
Take pictures of it so we can see what it does have. If it has an electronic TJ 4wd switch, then it's as simple as just swapping the switch.
Is it actually staying in 4high or is it just the light stays on? If the transfer case is working then you should really be in 2high with the shifter all the way forward but the front right axle will still be connected like in the TJ with a straight single axle. That's still safe.
