Issues with oil pumps on these engines are so rare that I never see anyone changing them just because. Doesn't Make it a bad idea to do but they're pretty reliable pumps being that they're mechanical and just a set of gears spinning and creating suction. Designs like that don't fail often.
Put another way, if the pump is in a state where it will fail soon, it has likely seen some nasty nasty oil that would cause it to get to that point, which means that nasty oil has been around the rest of the engine too. So I'd bet if the pump actually dies on someone, the engine probably isn't in such great shape to begin with.
If you're doing a rear main seal and oil pan gasket, then I could maybe see swapping in a new pump "just because". I wouldn't go out of my way to swap it otherwise. If you do, I would recommend Mopar if you can find it (your Mopar is pretty old and good, obviously), or Melling. Melling makes good stuff.
