Howell TBI conversion kit fuel pump won’t work
What controls the pump with this conversion? The PCM or a new PCM? Newer injected YJ's have a safety feature that turns on the pump for 1 to 3 seconds to prime the injectors, then stops. Can you jump a fuel pump relay to get it to work?
I had a cj7 with the howell kit. for the most part it used chevy 4.3 parts with an inline electric fuel pump tapped into a hot when key on line. Im curious on a YJ how they do it but IIRC howell offers instructions on their website.
Yes the pump works when connected directly to the battery. It supposed get a signal from the Tach to the ECM (the main computer) so the to work but no signal.
Probably poking in the dark here but does or did the tach work? Jeeps can us a fuse to power something you'd never guess, so check every fuse, under the hood too. This might also be a perfect opportunity to hide a pump power supply switch hidden somewhere for anti theft purposes. If the engine is running, so is the pump.
