hard from some is easy for others. ?
there are vast youtube videos showing jeep trans and or transfer case pulls, it be wise to watch some first. and you be that judge of that! just you.
and tools. (got the tools)?? willing to buy them and be safer and even less work???????
got a tranny jack>?(harbor fright(sic) sold
yes my 4.0L pulled, (it all) in my 1988 Cherokee , the top bell bolts are the most hard. (new m/t clutch day) (this is pulling it all sure)_
but let the engine lean down lower, jack on engine rear, yes, lower and it goes lower all of it and have 2x, 18" , 3/8" ratchet extensions to reach them easy
the fan shroud can hit, so remove all fan shroud bolts. to all deeper lean.
exhaust header not in the way nor fighting engine lean.
YMMV, when I do it is take the extra steps to make it more easy.
also look in that huge hole in the center shifter floor hump removed that hands and tools can fit too.
then there stuck rusty bolts. to deal with. and in salt belt never impossible.
learn to use youtube first, then ask more better questions, after seen , no better way exists.
look see ask.
also the FSM covers all steps
read that yet? tranny pull
nv231case?
chapter 21 covers it. tranny
page C21, page 287 , step 3 states to drain the xfr case first (make sure filler hole plug is not jammed first.) then drain it.
unless a bath in ATF+4 is fun.
pdf 1849 of 2151 pages. total.
free to read at any time in the
STICKY here. posted 1000s of times.
94/95 fsm pdf get it keep it and read page 287, 16 steps there) and then ask questions.
here is a teaser page
just for you.
most guy doing this , work, is new clutch day too. top brands not from fleabay
only you know how old the clutch is, and matters to all M/T owners./
