My 94 4.0/manual has been sitting in the garage for just shy of a year and a half after my transmission went bad. Finally got around to getting it all back together with a new transmission from Novak and using the LuK clutch replacement kit. While I had it apart, I also replaced the rear main seal, oil pan gasket, and oil filter.
After getting it all together, I threw in some gumout fuel system cleaner in a full tank of old gas and took it for a drive with a mix of city and highways. I don't think it had any loss in performance at least from what I can remember. After getting the tank half-way down I put in fresh gas. Shifting into gears feels smooth and no trouble at all. I used Castrol GTX conventional 10w30 for the engine oil and Redline MT90 for the transmission. After driving it, I didn't notice any leaks or seepage. Oil pressure goes up to the line just above 40 and when I'm stopped, it drops down to the first line (30?) below 40. It idles solid, no bouncing RPMs or anything like that.
Here are the sounds from the engine bay that have me concerned:
From the engine bay: https://drive.google.com/file/d/1UnO81lOv6yBZEcZ-ksuAz8mcfLVgXy-M/view?usp=sharing
From beneath the engine: https://drive.google.com/file/d/1m2oOcDRQeapz7Q1rkRK6GXDQNHea6Rvs/view?usp=sharing
Should I be concerned? Is this lifter tap or pinging? Could it be related to the fact it has sat there for over a year and there is some kind of buildup or gunk? I've read about people using seafoam, should I consider that? Should I consider changing the brand/type of engine oil? Could it be possible the old gas could be causing it as well? Am I making a big deal out of nothing? lol
Sorry for all the dumb questions!
There is also rattling and it sounds like from the muffler, but I'm not sure. I used the screwdriver method and checked spots from the oil pan to the muffler. It sounds like its coming from the muffler but I'm not sure it isn't because the muffler was vibrating against the screwdriver. Looking at it, it doesn't seem to be vibrating. The head shield doesn't seem loose. On the way home is when i noticed the "exhaust" rattling sound and it doesn't make that sound when I start up. It's most noticeable when reversing into my garage. Actually I might try reversing into the garage with my phone recording on the floor and see if I can get an example that way.
I've driven a total of 70 miles, 60 of that on the old gas. I checked the ODB codes and I got 3, one for the battery being disconnected (12), the other for no AC (33), and end (55).
Thanks for your patience and any help would be greatly appreciated! I need to get the jeep smogged this weekend so hopefully I can get it done and won't need to strip anything back out before then.
