Headlight oddity
tugskipper
Milton, FL
Hello, has anyone had the following problem with your head lights?
Sometimes my lights will go off for no apparent reason. They don't stay off for long, just a few seconds and then come right back on. I have checked the wiring, replaced fuses, used dielectric grease on connections, etc., etc. Am I missing something?
When they go off try quickly switching between high and low beam.
Did you check the Hi-Lo switch attached to the steering column? They seem to go bad.
I'll bet you have bad grounds/dirty connections thus internally overheating an old headlight switch. This causes the headlight switches internal breaker to trip. This has happened on both my 91 YJ, 99 TJ.
