Door striker adjustment
TRevs
San Antonio, TX
I’ve replaced the rubber seal on the tailgate and I’m finding that the striker needs to move rightward in order to line up with the latch. I installed a new striker a few months ago and it came with one washer, but the parts catalog shows three (all discontinued of course).
Can I just use any steel fender washer of similar diameter to shim the pin outward?
Yes, whatever thickness you need.
I found grade 8 1/2” flat washers in a 3-pack at Lowes; two washers fit the bill.
Now the tailgate is solid and quiet; definitely recommend new seals if the existing one is old.
