Don’t buy that one. That’s an AX5 from a 2.5 Jeep. Will not bolt up to a 4.0 and wouldn’t hold up to the power if it did.I went ahead and canceled the deadjeep order. Here is the page for the facebook transmission:
[/URL]
[/URL]
Double post.I went ahead and canceled the deadjeep order. Here is the page for the facebook transmission:
www.facebook.com
Oh wow, either he doesn't know what he has or he is scamming. Ah well, back to looking for an AX15Don’t buy that one. That’s an AX5 from a 2.5 Jeep. Will not bolt up to a 4.0 and wouldn’t hold up to the power if it did.
Looks good so far. Some other things are the:And then from what I understand these are the parts I for sure need:
Pre-bled Master/Slave Cylinder $88.79 RockAuto
Luk Flywheel LFW193 $49.79 RockAuto
Luk Pro-gold Clutch 05-901 $173.23 Amazon (Do not need Throwout Bearing if buying Mopar)
Mopar TO Bearing 53008342 $95.69 Amazon
YJ Shifter $99.99 Ebay
Mopar ShiftBoot 53004539 $106.89 Factory Chrysler
View attachment 116805View attachment 116806View attachment 116807View attachment 116808View attachment 116809View attachment 116810
The giveaway is the bell housing pattern. The 2.5 has that flat top portion with the two bolts. That is a GM bell housing pattern since the 2.5L was adopted from the original GM Iron duke 2.5L engine back in the CJ days.What is the give away? I can't tell
Yup, that is correct. The transmissions themselves are somewhat difficult to identify so I like when they have the bell housings on them. Makes it easy.Ah, I see what you mean. Thanks for warning. I will let him know and see how he responds.
Posting a picture to show others the difference:
It’s definitely an AX5. Sad he doesn’t know it’s an AX5 based off of the fact it came from a 4cyl. The AX15 can be adapted to 4cyl but is a lot of extra work and not typical. So I guess he didn’t know what he had.He said it was swapped onto a 4cyl. I only found one source, and from what I understand is that the bell housings cannot be interchanged?
I saw something that said one way to easily tell in person is to use a magnet on the middle. If it sticks it is an AX5.
Can’t really say if it’s necessary or not. I could not get mine to drive without vibrations on a 2.5” rough country lift. Considering that and the fact that you may have to change the transfer case input gear (which requires completely taking apart the transfer case), I’d probably lean towards doing an SYE while in there. And you’re going to need driveshafts anyways so yet another reason.Is the SYE necessary if I only have a 2.5in lift? I am only guessing it is 2.5 because my shackles are longer than normal. I have 31inch tires and from ground to bottom of tub is 22in.
Used is fine for the front. Might want to check/swap the u-joints in it but otherwise it should be ok.For driveshafts should I get them used? I found a rear drive shaft for $96.99 from Deadjeep on ebay, and I found 3 different options for front drive shaft for about $200.00 on ebay.
It shouldn't as long as it's for the AX15. It mounts using 3 bolts, 2 are to the studs on the trans shifter, and the third is a large bolt that goes into the side of the transmission. As long as it's for AX15 it should work fine because all of them have the two studs and that mbolt hole. I have seen instances where AX15s from Cherokees didn't have that side bolt hole though, so post pics of the transmission before you buy so you don't buy one of those.Looks like there are a few ax15 transfer case shifters on ebay, does it matter the year?
Yes, they are cheap. Definitely worth replacing rather than using the ones that come with the transmission, if any do.Clutch fork spring and pivot ball are pretty cheap brand new it seems.
Sounds good. Doesn't need to be fancy, you'll never see it. You'll probably have to stretch the holes to get them over the shifter bases anyways (and they may already be stretched from whoever removed them from the Jeep it came out of). Definitely doesn't need to be pretty.The inner shift boot I found two for about 30 dollars used.
The cheap ones (lesser quality) would be Crown, Rugged Ridge, Omix Ada, Rough Country, etc. Ironically they aren't cheap. The one I recommend is JB Conversions Standard, not the super short. The super short is good but the speed sensors it comes with are pre-set and they don't seem to last very long with any heat. They require a programmer to adjust the speedo for different tires. I actually like that part, because you can get the speedo 100% correct, but I don't want that speed sensor since it doesn't seem to last and JB is the only place you can get replacements.For the SYE, does it matter the brand, or is it ok to find the cheapest possible. It looks like they range from $230 to $350.
Hard to say. They don’t have a defined mileage limit. Some still work fine at 300k, others have really worn synchros at 150k. Depends on the driver for sure, and they were all filled with the improper fluid at the factory so how long that fluid stayed in there also plays a part. Really no way to know.Found a 1998 AX15 on car-part.com that is still in stock at the salvage yard 2 hours away from me in Mississippi. It has 185,426 miles on it. The guy on the phone said it is $600 and it has the bell housing still.
Assuming it wasn't shifted too rough, about how many miles does the AX15 last before needing a rebuild?
Would certainly be worth a try to haggle him down.I wonder if I can haggle him at the junk yard. It has been sitting there since 2018.
Where is a trusted place to get a new one?
