I’m trying to track down a clunk/rattle from the rear end, and I found that both rear wheels do this:
Is that the ‘C’ in Dana 35C?Im guessing if you jacked up the ass end you'd find the wheels will move in and out a bit. That is normal with a C clip'ed axles.
The C in 35C is for ‘custom’. Chrysler ordered them without brackets from Dana, so they were incomplete, or, "custom."Is that the ‘C’ in Dana 35C?
I don’t think so. There are a lot of noises but I don’t think any of them are bearings. Exhaust leak, lifters etc yes.Just to be sure you are not getting any up and down movement are you? Like in bad wheel bearings. If they are worn you'll have a good growl sound from the rear end as well. Google up D35 spider gear replacement and watch one of the the youtube vids and you will learn what were talking about.
With my 18-y/o jumping in the bed of the Jeep , I was able to localize the noise to the front bushing of the left rear spring. I removed the bolt, lubricated and re-torqued everything and everything is much less creaky now. Thanks!Urethane leaf bushings are notorious for creaks and squeeking. Make sure the spring plates/U bolts are not loose also.
