DeltYJ New Member Joined Nov 15, 2021 Messages 24 Location Klamath Falls Oregon Dec 5, 2021 #1 So I bought this jeep I need to figure out the make of Tranz before taking it to ammco the stock room gage means nothing the engine is maxed out in second at about 2200rpm second seems lower
machoheadgames Certified YJ Researcher Supporting Member Joined May 19, 2020 Messages 2,505 Location Dallas, TX Dec 5, 2021 #2 That’s a Peugeot BA 10/5. I don’t understand the problem you’re having. Reactions: Chris
Gilaguy23 YJ Addict Joined Apr 12, 2021 Messages 1,166 Location Q town New Mexico Dec 6, 2021 #3 machoheadgames said: That’s a Peugeot BA 10/5. I don’t understand the problem you’re having. Click to expand... What macho said?? slipping clutch or geared uber low running the RPM's up higher that you think it should be??? help us out here. Reactions: DeltYJ
DeltYJ New Member Joined Nov 15, 2021 Messages 24 Location Klamath Falls Oregon Dec 9, 2021 #4 Gilaguy23 said: What macho said?? slipping clutch or geared uber low running the RPM's up higher that you think it should be??? help us out here. Click to expand... Gilaguy23 said: What macho said?? slipping clutch or geared uber low running the RPM's up higher that you think it should be??? help us out here. Click to expand... Exactly what you said its geared Uber low running up the rpms yet. Is that doable with that transmission? Yes the clutch sometimes sticks so I pump it
machoheadgames Certified YJ Researcher Supporting Member Joined May 19, 2020 Messages 2,505 Location Dallas, TX Dec 10, 2021 #5 This doesn’t make any sense. 2200 rpm is not “running up the rpm”. You’ll be fine at whatever rpm you drive at so long as it’s not past redline.
