Recently added a 4" RC suspension lift. Kit came with everything, springs, shocks, longer pitman arm, track bar bracket, ect (no shims). This is new to me and since added the steering is a little jerky from side to side. It's not crazy bad, but it's there. I'm running 33's x 12.5 x 15 wheels and tires also. From research, I'm understanding that these lifts throw the caster angle off which causes this jerky steering.
I've read that some disconnect the track bar to help this movement, which I did and it help to make it manageable down the highway. To me, the track bar shouldn't be disconnected as it keeps the axle in-line and without it the only thing you're relying on to keep the axle in-line are the U-bolts.
I have spoken to a few YJ owners personally and I get some say to add shims and I've seen some without shims and all are sitting on the same 4" lift.
This is becoming confusing on my direction to correct, shims or no shims, track bar connected or disconnect....or is there something else ?
Thanks in advance
Thanks in advance
