1990 Wrangler, 4.2 6 cylinder, EFI Fuel Injection
For several years, especially in temps below 30°F, after running awhile at cruising speed, a loud whistle would come from the engine compartment when I removed my foot from the gas pedal (throttle plate full closed). The whistle wouldn't last long enough to pull over and check it out. I ended up replacing that engine for other reasons, and the new engine didn't whistle any more.
For a while, anyway. Eventually, the whistle came back, getting worse over the course of a year and began to occur at warmer outside temps. I started carrying a mechanics stethoscope to try and capture the event.
That finally happened on a lonely stretch of road where I could stand on the brakes, get out, open the hood and listen to some components before the whistling stopped. It was coming from the gasket interface between the intake manifold and the engine cylinder head. At maximum intake vacuum, air was whistling past the manifold gasket.
I found the two rearmost manifold bolts to be loose, one finger tight. I re-torqued them, but the damage was done... I could not close the gasket junction enough to fix this leak. Also, the exhaust manifold was blowing by in the same relative location. This makes sense because the intake and exhaust manifold share common "hold-down" bolts.
So I had my favorite shop recondition the intake manifold, get me a new exhaust manifold, gaskets, and new attaching hardware. Everything cleaned up nicely and went together tight, torqued to maintenance manual specs. We also had a nearby muffler shop send a welder over to release and reset the exhaust pipe loads on the exhaust manifold, slightly relocating the pipe routing.
Drove about 600 miles including on some rough terrain and took the Jeep back into the shop to check the manifold bolt torque (among other things) and found the 4 most aft manifold bolts to be loose. No leaks, no whistles, but loose bolts. They are tight now, but it is clear to me that between two engines and two exhaust manifolds, the rear manifold bolts work loose with vibration loads over time.
Are loosening manifold bolts a common issue on the inline 6 Jeep Wrangler engines? I have a strong urge to intentionally over-torque those rearmost bolts.
