94' Drive belt tensioner bolt assemply
Sogent#01
Need a drive belt adjustment bolt and collar for 94 6 cyl wrangler. No one seems to carry 94. Bolt is broken and rusted into collar part of assembly. Would newer ones work on a 94? Other advice? Thanks in advance.
Pretty sure there is a Dorman replacement part that works as stock. I don't recall the part number but Ive seen it recommended on Facebook a few times. Might look into that. Newer versions like late 95 and all the 97+ Tjs won't work, they use a completely different tensioning setup. You could convert to that setup I guess but it wouldn't be easy to find the parts to do so. But no, as far as I know you can not just take the tensioner bolt off a later setup and use it on yours, very different setups.
Reactions: Sogent#01
I would call “Daveys Jeep’s “, they are a jeep salvage yard in northeast Ohio. They will ship parts around the country. Be sure and tell them exactly what it is that you need, no refunds.
