When you in stall spring shackles how tight to do you make them. My 95 has a 4 in lift with stock shackles I'm guessing. I have removed the track bars and the sway bar and I still can not get any suspension flex at all. If I get a front tire on say a rock 8 inches tall the jeep stops in it tracks in four wheel drive. It will spin one back tire and one front tire. This is on level ground trying to pull up on a rock I have in the yard. One more thing I am going to try is backing off the shackles bolts to see if who ever lifted this thing went crazy and over tightened the bushings down and it just binding up. If that is the problem, just how tight are you suppose to tighten them down.
Thanks for the help.
