Newly purchased 1990 YJ 4.2 with a Weber carb.
The issue(s):
Everything was fine when I did the test drive before buying it. On the way home the temp gauge slowly crept up all the way to just under the red mark and stayed there. When it got hot, it started sputtering and bucking like a bronco when taking off from a stop light, and would stop sputtering after a few seconds, then keep driving normally. I also noticed it's hard to start hot. Cold starts are easy and fast, but only hot starts are difficult. And also, this thing get's 8mpg on a good day. I know it's not an eco car... but wow that's bad. And it only holds 10gal usable fuel (stock metal gas tank). I looked under the hood, and noticed that someone installed a 2" body lift to clear the 31" tires, but this caused the rad and fan shroud to be misaligned with the engine driven fan. So the bottom of the shroud had been trimmed off since it was obviously interfering with the fan because of the body lift, and the top of the shroud isn't helping much since it's sitting so far up... GRRRRR. I also noticed that for some reason whoever did the Weber carb conversion blocked off the return fuel line to the tank, and got a fuel filter that doesn't have the return outlet on it. Not sure why it was done that way, but I'm wondering if that's causing some of my problems.
What I've already done:
Replaced the fan clutch (standard duty), replaced the thermostat (180*), flushed the cooling system, and refilled with new coolant. That at least is keeping the temp gauge out of the red, but it still runs past 210*, which I'm not comfortable with, and is likely causing vapor lock that then causes the sputtering.
What I'm considering:
I want to install some sort of throttle body fuel injection system, with an electric fuel pump, and get a 20 gallon fuel tank and sending unit from a later model YJ. That should address my fuel capacity and mileage issues. I also want to get rid of that God awful body lift, and get stock height polyurethane body mounts, and either a proper suspension lift (currently considering BDS BDS408H) or just rebuild my stock suspension since I really like the way it rides, and go back to stock wheels/tires. I'm not a hardcore offroader. I mostly run down gravel trails for recreational purposes. Then my rad and engine fan will be in the correct position, and I can replace the fan shroud, which'll get that back in working order. I might also go ahead and replace the rad with a heavy duty aluminum one. I believe that the rad that my Jeep currently has is the original one.
I really love my YJ, and it can definitely be saved. It's a very nice Islander model package, too. I just need to be pointed in the right direction to get the aforementioned issues fixed.
Thanx all
The issue(s):
Thanx all
