YJ not starting after replacing the carb and putting an HEI in it
Butchlee25
Utah
So, we replaced the carb with a better one from a Chevy. Not exactly sure on the model. But, then put an HEI in it and did the timing and everything, got power and got the tach ran. Now, we’re getting spark, and still won’t run. What could be causing these issues?
NO YJ year told no engine told of many.
we can not see under the hood ,okay? nor read the VIN.
carb float bowl full of fuel. ???? check pump fuel pressure yet? no pump told.
no carb told but if has HS accelerator pump it works and sprays fuel in the carb air horn venturi, to see if fuel is good.
is the choke working?
testing 1,2,3.:
does spray can test fuel work?> if not spark is bad ,weak or timed all wrong. or worse. (engine dead)
YJ means zero to me, only what is there now matters. after up to 37 long hard years.
GM HEI, sure.
does it have a GM engine too?
Have you tried Starting Fluid while cranking? That will help determine if a fuel or ignition problem. I recently installed an HEI, had big problems with timing, it was off by 25 degs out more (retarded), once I started monkeying with the timing I got it to begin firing, then I knew I was on the right track. Good luck.
