9 94wyj New Member Joined Aug 31, 2023 Messages 2 Location Summerville SC Aug 31, 2023 #1 I have a 1994 yj. Put on new led tail lights. Everything works but I have dim blinking on opposite sides on all ( front turns, side markers and rear)
machoheadgames Certified YJ Researcher Supporting Member Joined May 19, 2020 Messages 2,030 Location Dallas, TX Aug 31, 2023 #2 Just to confirm, you left the front turns and side markers incandescent? If so, did you change the flasher relay?
OP 9 94wyj New Member Joined Aug 31, 2023 Messages 2 Location Summerville SC Aug 31, 2023 #3 machoheadgames said: Just to confirm, you left the front turns and side markers incandescent? If so, did you change the flasher relay? Click to expand... Yes I did all of that. I just found out that it was a ground issue. Ran a new ground wire to the frame problem solved. Reactions: ytradio
