i bought a 93 yj with 8.8 3.73 rear end and a dana 30 3.07 front end what the best and cheapest way to match these ratio's
Wouldn't he want to find a 6 cylinder Dana 30?If you could find a 94-95 auto 4 cyl dana 30 that has 3.73s.
I thought all the 4 cylinder YJ’s has 4.10’s and the 6 cylinders had 3.73’s...
Mine as purchased,(2.5L 4 cylinder 5 speed) with 33x12.5x15’s) good for 50 to 55 mph. Found out it had the wrong gear sets installed. He recommends going with almost stock size tires and 410’s front and rear to “help” the issue.Mine is a '92 with the 2.5L 4cyl. 5 speed and with 31in tires it's a slow dog in 5th gear. It was recommended to switch out to the 4.88 for better performance. Right now I can hold 50mph on level ground in 5th but not much more.
Unless you’re dropping all the way down to fully stock size 27” tires, I would really advise against 4.10. I’d say go to 31’s and run 4.88 gears. Even stock tires on 4.10 struggles a bit. 4.88 and 31’s is better performance than stock and certainly looks better than a fully stock YJ. Keeps a bit of the cool factor and increases performance overall. A regear costs the same no matter which gear ratio you pick, so choose wisely....Mine as purchased,(2.5L 4 cylinder 5 speed) with 33x12.5x15’s) good for 50 to 55 mph. Found out it had the wrong gear sets installed. He recommends going with almost stock size tires and 410’s front and rear to “help” the issue.
Nope not at all. 4.0s could have either 3.07 or 3.55. The majority of 5-speeds were 3.07 and majority of 3-speeds were 3.55. That was not a rule though because there are plenty of manual 3.55s (me), and plenty of 3.07 autos. There was not much rhyme or reason as to what each one came with.Wouldn't he want to find a 6 cylinder Dana 30?
