Hi All , I need to put a automatic transmission in my 88 yj and get rid of the Peugeot five speed , what should I put in my jeep?
Finding a stock 3 speed out of an 87-91 is the way I'd go if I wanted to swap and had an 80's YJ.
Can a stock one handle about 275 horsepower
Probably? I don’t know. You don’t have a lot of options.
So what do u think try it and c what happens
why are you going from a standard shift to auto? it going to take alot of work as well as money. i think your yj looks real good.
Dang, do you have a hot stroker or modern swap under the hood? The gen 3 LS in my Grand Wag is rated about that.
The early 5 speeds were weak. Not surprised at all that you smoked one of those. They were just a poor design all around.
The stock autos and the AX15 are stout. I would also be extremely shocked if you were actually achieving 275HP. The boring of the motor will help things some, the exhaust won’t do hardly anything at all and the carb will make it run more reliably but it isn’t gonna boost power like that.
For what it’s worth, you could have smoked the 5 speed with a stock motor, your new motor is not why that happened.
Also, consider a Regear. I can’t tell what size tires you have but they are clearly larger than stock. A Regear will lessen the stress and heat buildup in the transmission so that once you do swap, it will live longer. If you have 3.07 gears and large tires, that’s a good recipe to kill an auto due to heat from the tall gearing.
Hi I have had both axles rebuilt with 4:11 gears and 33” ,12.5 wide tires . How can I make more power with the engine I have
