What Differential Fluid Are You Using?
zebraranger
Florida
93 YJ 4.0 5 speed manual with Dana 30 & 35. After getting this jeep 3 months ago, I've been going through it, changing fluids and fixing things that needed attention. Next and last thing is the differential oil, I was just curious what you all are using, there's a lot of different brands out there.
For my limited slip salads…
I always use 85W-140 conventional from Currie. It's thick, keeps the diff quiet, conventional is known to extract heat from gears better, and conventional leaks far less from axle than synthetic. So I stick with it. I also choose them because I run TrueTracs which are not supposed to have limited slip additive. They were the only gear oil I know of to not have the additive.
Reactions: zebraranger
I went with the cheap stuff from Advance Auto - Carquest gear oil. It is actually highly rated and I change my fluids often. I only drive it a few times a month on flat roads so very little stress or strain.
