SYE recomendations
TJ701
NORTH DAKOTA
i installed a RC 2.5 lift on my 93 YJ and trans drop . still a little vibration so im going to install sye and get rid of transfer drop. any recomendations on best manufacturer or brand? also will a standared 16.5 drive shaft work with it? ive read some reveiws where there was drive shaft length issues standared drive shaft
I like the standard SYE from JB Conversions.
The problem with your vibes with rough country is they put giant shims on the leaf springs. They should not be there. Best way you can set the stock driveshaft up is change to 2° shims on the springs and use the RC t-case drop.
But, nothing wrong with going through SYE route either.
