Speedometer not working
bobbyk3
Clovis Ca.
1995 Wrangler with Teraflex Extreme Short Shaft SYE. Speedometer stopped working a few days ago. Replaced the VSS and still doesn't work. Took the dash apart and inspected the speedometer ribbons and they look clean (see pic). Where do I go from here??
I will, but how would that affect the VSS?
The super short SYEs delete the speedo gear and go with a tone ring and the pickup sensor instead. The tone ring can become loose and spin if the nut isn’t tight enough. You wouldn’t think that happens often but I’ve seen it mentioned quite a bit over the years. If that doesn’t fix it then you may have a short in your wiring somewhere up the line.
Appreciate it! I'll check that nut then. I DID just put in a new transmission output shaft seal a couple weeks ago, so maybe it didn't get tight enough.
Should I also pull the plug to the speedo/tach cluster and check and see if I'm getting voltage to the #13 pin? I believe that's the pin to the speedo.
You could. I think you’ll see 5V there and I believe that splices off the PCM. So I’m not sure verifying 5V there really tells you much, but maybe. It’s been a while, I don’t really remember how the speed sensor works.
edit: I went back and reminded myself how it works. PCM supplies 8V sensor power and ground on the orange and black wires going to speed sensor. The orange/white wire is the wire that the sensor pulses to provide feedback back to the PCM, instrument cluster, and DRL module if equipped (Canada).
To verify your wiring is good, you would want to check continuity on the orange/white wire from the cluster to the speed sensor, and you’d want to verify that wire has no continuity to ground. As long as those are both the case, then it isn’t the wiring. For whatever reason, checking voltage on that wire shows 5V or it always did for me at least. I don’t know why, the power source is 8V provided by PCM. No clue why the power after it goes through the sensor comes out as 5V on the orange/white wire.
Looks like the VSS is good. Can't post the video, but it alternated between these two signals as I spun the drive-line slowly. What now? Where else does this signal wire go to other than the PCM?
