Right Leaf Springs?
jaysyro
New York
2 questions
1 - I have a 4 inch lift to my 92 YJ. The kit I used was a rough country lift. I just swapped out the springs for Rubicon Express Springs. Made for a 4 inch lift. Each new spring, front and back, are identical. Am I supposed to have different Rubicon Express springs for the front as opposed to the rear? Or all the same?
2 - My mechanic swapped the Rough Country springs out for the Rubicon Express ones without installing anything additional. No additional shimmy’s for the rear springs or anything. Did he do it right?
According to RE's website the "standard 4 inch lift spring pack"s are the same for front of rear, part #1425 which should be visible on the top of the spring packs. The extreme spring packs are different. Far as parts go the shocks should be fine and the rear diff shims are probably the same either kit. With a 4" lift you running a SYE?
