UPDATE: POSSIBLY SOLVED
I didn't want to leave everyone hanging without a followup, so here it is (with photos).
Today I pulled the old fuel injectors, dropped the tank, and found the issue (or I hope I did). Two of the injectors for cylinders 3 & 4 (rear two) had oil inside the injectors, as well as the fuel rail on that end...plus some sludge buildup which I assume was a mixture of fuel and oil. As soon as I pulled the injector for cylinder 4 fresh oil (from the recent oil change) was dripping from the injector on the fuel rail side. I cleaned the fuel rail out to the best of my ability before installing the new injectors and reinstalling the fuel rail.
The new fuel pump was placed inside a new bucket with fresh fuel, and the return hose was placed into another new bucket so I could keep any contamination from going back into the system. I primed the fuel line a couple times and she started right up. None of the original symptoms were present, and I let the engine run for only 30-45 seconds before shutting it down to check the fuel rail for leaks as well as to ensure my fuel system was functioning properly. I fired her back up and let the engine run for another 90 seconds. At that point I checked the return bucket (see photo for results). I should have swirled the fuel in the bucket before putting it into the clear cup because I noticed a lot of carbon buildup and chunky oil sitting on the bottom of the bucket that did not make it into the clear cup.
I removed the fuel rail and injectors to ensure oil was not going back into the fuel rail, and was pleased to see nothing but "clean" parts. Happy with the results I fired her back up and let the engine run for another 90 seconds. I assume I was pushing roughly a pint (16oz) of fuel per minute through the system based on what I saw in the return bucket, but I did not measure the results other than the clear cup that you see in the photo. The fuel that was coming out was MUCH cleaner at this point.
Now for the fuel tank.....after dropping it again and draining the remaining 1/2 gallon (64oz or a "growler" of fuel) I took a peek inside with a bright light. I was absolutely amazed at the "berg of sludge" that was inside (see photo). I truly have ZERO idea how so much crap got into the tank since it was fully cleaned out prior to all of this. When I say fully cleaned I mean hand-scrubbed on the inside with some grease destroying soap, rinsed out multiple times with hot water, and left to air dry upside down for nearly two weeks before being reinstalled. Today, I did the same thing and it is now drying once again. There is NOTHING inside that tank that shouldn't be there. I didn't measure the "berg of sludge", but my best guess is around 10-16oz, and it was thick & slow moving like bearing grease. It was kept away from the old fuel pump due to the slosh box around the pump, but the amount of other crap was what clearly caused the failure.
RESULTS:
This problem has never come up before, and I have never seen oil get into a fuel tank like this. I've asked quite a few people about this and not a single person has heard of this. Best guess is the fuel injector(s) failed and some cylinder blow-by was pushed into the fuel rail, or something crazy happened and there is no simple answer for this issue.
I am going to let the Jeep sit for the next few days with fresh fuel in the system before I run another gallon or two through it and check the results. If clean fuel is coming out the return line I will get everything buttoned up and update this post if the issue continues.
Thanks All!
Patrick
RESULTS:
Thanks All!
Patrick
