Did you disconnect the battery to clear the code?Ive already bought 3 IAT sensors and still throwing code 23. Ove used dielectric grease abd cleaned the throttle body. Please help.
Rebuilt 2.5 ax5
Thanks in advance
Yup twice and ran through the code still came up. Thinking of moving it to the air box.Did you disconnect the battery to clear the code?
That sensor works off of voltages. Have you tried testing any of the pins to see the readings you get?Yup twice and ran through the code still came up. Thinking of moving it to the air box.
Ya they seem to be around right reading but every other start up or couple of tines it will come on.That sensor works off of voltages. Have you tried testing any of the pins to see the readings you get?
Weird. I wonder if you have a larger issue like the PCM bad or something...Ya they seem to be around right reading but every other start up or couple of tines it will come on.
Before this it was the 02 sensor and fixed that but now it's just that code and a short in the vss.Weird. I wonder if you have a larger issue like the PCM bad or something...
Good luck. I’d probably go grab a quick one out of an XJ at the junkyard if I needed to perform that experiment. I can’t really see anything else causing this repeated issue. Hopefully the new one solves it.Just a quick update I relocated the sensor and no luck if I clear the code and run it its fine. But then restart later and comes back up.next step rework the pcm. Wish me luck.
True but down here hard to come by plus cheaper to fix. Thank you tho ill post update asapGood luck. I’d probably go grab a quick one out of an XJ at the junkyard if I needed to perform that experiment. I can’t really see anything else causing this repeated issue. Hopefully the new one solves it.
I’m surprised they caused you an intake temp code, I am not surprised they gave you issues though. I’ve seen a lot of people run aftermarket injectors and they frequently have problems. I’ll always use OEM for sure. Glad to see you got it fixed.So ive been hitting my head against the wall but i think I finally found it.
So after the rebuild of the motor I wanted to switch to a electric fan and more power injectors and small things for now but the only thing i was able to do is the injectors
To a four port. Well I finally had enough and thought to myself why am I throwing codes. So i switched back to the oem one port and bam fixed. Lessoned learned dont trust a good deal. Thank you @machoheadgames for tryijg to help out. Now next is wheel hubs and ball joints then suspension ill do a thread
