Full throttle gives a rattle sound
jpjeep26uk
UK
Hi all.
I'm a slow driver but every so often I put my foot to the floor to overtake/boredom.
When it sounds like my second Venturi? Kicks in the car speeds up.
Excellent!
Until......
There appears to be a metallic rattling when I fully open her up coming from inside the cab?
Nothing serious or loud just a high picked rattle?
Any ideas folks?
Thanks!!
My heater fan box linkage rattles at a very specific rpm and can be very annoying. I can't lean over while driving to find the exact cause.
Good shout. I've got a long and fast drive this afternoon so will take a long stick and prod the heaterbox when the rattle starts. It sounds like a chattering highish pitched sound like a spinning bit of metal clattering with another bit of metal. I'll try to record it or be more precise after this afternoons petrol thrashing drive!
do you still have the cat converter? my guess.
I do believe so Earl, even though a few sites tell me I don't.
I'm under the Jeep this morning so I'll snap some shots and post them.
I have a strange looking box directly under the cab, sort of a flattened muffler which then goes into a proper looking muffler then straight out the pipe.
That sounds like the cataclysmic converter your're describing. Try rapping on it with your hand and listen for rattles. They seem to be short lived on jeeps for whatever reason.
Same issue on a 94. On mine, there is a heat shield or something that is tack welded to the top of the converter, and a heat shield above the muffler. These were rattling at specific rpm’s. Super annoying. I bent them as best i could by hand until it stopped. I doubled up some tie wire around the converter to stop that rattle. All good for now.
Reactions: jpjeep26uk
I've tried everything and hunted high and low for that strange metallic rattle and no joy. It only happened when I engage the 2nd venturi in the carb and open her right up. Happens in 2,3,4, 5th gear. Very odd.
