Electronics with standalone ECU
Kaelinator
Houston, TX
Hi y'all,
I was wondering if I could get some direction on where to learn how I need to hook up my electronics for my Jeep. I really just need the turn indicators, high beams, horn, etc. to help me pass inspection. It's a '95 YJ Rio Grande with the 2.5L 4cyl. I'm using a standalone ECU made by Holley for a 5.7L Hemi, P.N. 550-1423.
I only have a few days to wire this correctly. Any guidance is appreciated.
Thanks!
Why try to adapt a nomatching? sounds like a nightmare of custom wiring and headaches. Has factory wiring,column switch and the like been torn out?
Nothing has been torn out. In fact, the stock engine harness is still intact. What is nomatching? I wasn't looking to do much custom wiring if I don't need to.
Meant to say non matching ecm. I cant imagine a ecm from a hemi V8 mopar being anywhere close to a 95 jeep 4 banger ECM. If the OEM harness is in tact why not fix or replace with Jeep parts whats not working. Keep in mind ECM's from close year wranglers arent even compatible from jeep to jeep with calibration codes for emissions ect.
I'm doing an engine swap to put the 5.7 into the Jeep. It seems like everything on the Holley will work fine, but I'm unsure about the rest.
Well that makes sense. What are you using for a tranny and T case? Should be a screamer when its done.
It goes: 5.7L, '92 Dodge Dakota bellhousing from a 3.9L, '97 AX15, np231
Flywheel and clutch kit is from a '04 Dodge Dakota with the 4.7L
Brake upgrade?
lol
I was also thinking about doing this swap. I have an 04 Ram 1500 with some significant body issues (both of my daughters drove it as their first vehicle). I bought it new in 04 so I know the drive train is sound. Was wondering if I could use motor trans and tcase.
