If you are able to remove tank, I would flush with water then I would use a muriatic acid solution. Let it soak, then repeat a few times. Rinse very well with water. Then dry very well, using a hair dryer or something similar. Be very careful with the acid of course. Muriatic acid can be found at hardware stores, Lowes, etc.
