Boomerang shackles
RedWrangler
Birmingham, AL
I'm looking to upgrade the stock shackles to a 1.25" boomerang. I am wanting to slowly upgrade my stock yj. Improvements in ride smoothness are top priority as it is a daily driver. I have a couple of questions/concerns;
Will I need to upgrade anything else going from stock to 1.25" boomerang shackle?
Should I be upgrading to a greaseable shackle?
Is this worth doing, or should I start with new leafs and shocks?
I appreciate you comments. I like doing the work myself but don't know what I do not know.
Thanks
start with a 1-1.25” body lift. Shackle lifts suck. 0.5” shackle lift is relatively ok but any shackle lift will be felt drastically in the steering. A 1.25” shackle lift will yield really poor handling. They also look like buck teeth.
Reactions: Stoopid Jeep
Generally speaking, yes.
But I believe I read that OME boomerang shackles are about 5" in length. I imagine they would drive fine.
Don't you think?
I'm too cheap to find out. I'm running 5.25" Ebay specials. They're ok.
Don't you think?
It’s been a while since I measured my OMEs but they are around 4.25” off the top of my head, so like 1/8” lift. I will say I don’t notice anything from those. I did have some 3/8” lift shackles from MORE and 1/2” lift from RE (so 4.75” and 5” respectively) and I did not care for either. Both made the steering on mine feel pretty loose.
I was mostly trying to advise against the 1.25” lift boomerangs the OP mentioned which would be a 6.50” shackle. Those will for sure handle poorly. Although I guess that is in the eye of the beholder. The good news I suppose is shackles are cheap and easy to change either way so it’s not like you’re missing a ton of money or out a bunch of labor if you put some on you don’t like. Can always easily revert back.
Thanks
If you are looking for an improvement in ride quality start with the basics.
  • Shocks
  • Tire pressures
  • Load rating of the tires (start with load rating C)
  • Amount of sidewall on the tire
