I have a 95 4.0 YJ. And I need some help, bad.
Last week I had an overheating problem out of nowhere. I was about a mile from home and had to stop, let it cool then kept moving. When I pulled in my driveway, the power steering was going out and it just died. I pulled it into my barn from there. Radiator, water pump, fan clutch and hoses were all original so I decided to replace them all. Got it all put back together, filled it up with antifreeze, got about 3/4 of a gallon in and it started leaking in the bottom of the engine around the oil pan. It’s just coolant, no oil mix.
Could this be a cracked head gasket? Freeze plugs? Something else?
Fire away!
Fire away!
