names in the USA all names for EFI are by SAE , and are a standard here. and in 1996 many names changed,
case in point CPS is now gone,CKP is new name for crank sensor now and forever.
TPS is still TPS
but the output pin is now called throttle angle, 1995 is call TPS signal; pin this is what the ECU sees and never the other 2 pins.
but pin number never lie. the FSM shows them .
The names are not ISO used in Europe, ever see a BMW service manual with wild crazy names, there. (dont look or go mad)
I do not want to argue names of parts, that is not my intent,ever !
what I ask for is use the FSM names or tell the TPS wire colors. of the pin numbers probed.
or show photos of meter connections,
is the CEL glowing running>> still
keep in mind I can not see you do tests.(me mr. blind)
so using correct names or pin #1 are paramount to success.
I posted the TPS real schematic above. so it is clear how Jeep names those connections in 1995.
let me say now GOOD LUCK!
TPS is still TPS
