On the AX-5 manual transmission, there is a "Do Not Remove" plug. I haven't touched it although I did do a transmission fluid change a few months ago. I used the correct fill hole that's up and to the left of that "Do Not Remove" plug on the passenger side.
But, today, I noticed that I was seemingly leaking some fluid from that "Do Not Remove" plug. I felt it, and I could tighten it by hand ... It was that loose. I don't have the tool that's used to remove that plug so I just took some slip pliers and tightened it down as best as I could. It also seemed to have a gasket/seal behind it. Any ideas how/why that plug would become loose? I'm now nervous that I'm low on transmission fluid b/c of this leak.
Also, on the driver's side of the transmission, I have another plug that has the blue paint mark on it (I'm assuming from the factory). Any idea what this plug is for?
