1992 YJ 4.0 engine.
Water pump bearing was worn out, allowing plenty of free play on the shaft. You could wiggle the fan blades sideways considerably. Engine was not overheating, though.
Replaced the water pump. Compared both new and old pumps side by side, and impellers looked identical. New pump was marked as "Reverse" as well.
Replaced the thermostat in the same job.
Started engine and everything worked fine while idling. Took it for a drive and the engine overheats before reaching one mile.
I though perhaps the new thermostat was the culprit (the new one didn't have the "jiggle" valve). Installed the old thermostat back. Still overheating.
This is what I know:
- I run vacuum in the cooling system before filling it out with 50/50 coolant.
- If you run the engine with the radiator cap off, there are no bubbles showing, and no oil in the coolant either.
- If you leave the engine idling, it doesn't overheat.
- If I connect a water hose down the radiator cap port, water comes out of the radiator lower port.
My reasoning is: the engine was not overheating before, and I replaced thermostat and water pump. Thermostat doesn't seem to be the issue. Before pulling the water pump out, I thought perhaps other members have experienced something similar. Any thoughts please?
