1992 2.5 Jeep YJ power steering pump adjuster bolt
White J
Ellerslie Ga
Trying to adjust belt tension.The bolt broke in my powersteering bracket. I need a replacement bolt and probably the other end. Does anyone have one? Or know where I can get one.
Deadjeep.com may have it
Also if you don’t have a 1/2” ratcheting wrench consider getting one as it makes the job very easy
mopar,com,/crown/dorman, all three have that bolt on e-day. fastenall in your city will also have it, but you might have to purchase more than one.
I need to know what size the bolt is and also I need the part It threads into that actually moves the pump because the other end of the bolt is broke off in it
look at the one on autozone." dormwn drive belt idler pull adjust bolt kit. *917-951. good luck
parts breaker on ebay has belt bracket/bolt/collar/ # 53002913/ fit 1991-1995 yj 4 or 6 eng/ 49.99
Took it apart today. Use the blue wrench to break the old broken bolt loose and removed from the adjuster lug. Went to hardware store got a m8x90 ss bolt and lubed it with anti seize. Works great and cost 4:19 cents. Job done.
that very good information, i going to write that down for further use. thanks and good luck
