Trying to adjust belt tension.The bolt broke in my powersteering bracket. I need a replacement bolt and probably the other end. Does anyone have one? Or know where I can get one.
I need to know what size the bolt is and also I need the part It threads into that actually moves the pump because the other end of the bolt is broke off in it
Took it apart today. Use the blue wrench to break the old broken bolt loose and removed from the adjuster lug. Went to hardware store got a m8x90 ss bolt and lubed it with anti seize. Works great and cost 4:19 cents. Job done.
