Trying to find the correct engine frame mounts
McLinder
Massachusetts
I am replacing the frame on my 93 YJ with one that is in better shape. The problem is the frame had the 4 cylinder motor mounts on the frame cut off to install a different engine (no clue what they had in it). No matter how hard I search, I cannot find new or gently used frame engine mounts (pads). I have found 6 cylinder ones I can weld on, but no luck on 4 cylinder. These are the mounts that weld onto the frame that the engine sits on. Any help finding this is appreciated!
I would give Throttle Down Customs a call. They make complete replacement frames, and put different mounts in them for different engines. They could probably make you a set of mounts.
Reactions: Fouledplugs
